new at 3D Fliying
new at 3D Fliying
Hi all
i want to get into 3D giant planes , i am a pattern pilot , and i have one O.S. 140 RX TO TRY with 3d. the question is , what kind of plane can i get that this engine work?what kind of planes (yak ,extra or something) has the tunnel pipe(becouse the pipe its some long).
Thanks for help.
Sergio Velásquez.
Thanks for help.
Sergio Velásquez.
My Feedback: (13)
RE: new at 3D Fliying
You might try something like this. availible from: http://www.peakmodel.com/index.php?m...eyword=YAK54-B
A 25% Yak. I believe the 140 should pull it around pretty good
My Feedback: (9)
OR
1 would probably try to stick to a wingspan size of about 70" - 75" and about 10-12lbs. Any of the above airplanes you mentioned would work really well. Yak 54 , extra 260/300 , and also take a look at the sukhois. Some people prefer the edge 540.....myself , i have never liked the way the edge flies. It just doesn't seem to fit my flying style. Most of your extreme 3D airplanes will have a mid-wing too , and those first airplanes mentioned work very well. Also....if you can find one , a Katana or Funtana is really good too and are under rated.
BC, CANADA
Getting your motor to perform in the powerband for 3D is most important.
You will need torque from idle and response time to be quick.Power from midrange to peak is last ideal.
Prop selection is key also.
A 68-72 inch 10 pounder is about right.A tunnel is hard to find in the smaller ones.
Perhaps the QQ Yak? an Extreme Flight? Wildhare or Aeroworks small scale? There are many others,depending budget.
OH
check out the aeroworks yak 90-120 free shipping right now http://www.chiefaircraft.com/rcmsec/.../AWYAK120.html
it doesnt have a tunnel for a pipe but there has been some people that have made one and wasn't to bad of a project. of course i wouldn't know were to
begin but some people are really good at this stuff.
