 what is better >
what is better
what is better
Old 11-07-2009 | 08:56 PM
Default what is better
what is better for 3D and free stile aerobatics? a flatter pitch prop or one with high pitch ? or is diameter better?
Old 11-07-2009 | 09:12 PM
JOHNS3D's Avatar
Default RE: what is better
hu?, it depends, engine, size, airplane, etc..... for example on my .81 alpha engine on my Edge i use 14x4W(wide) and it makes good hovers, etc. On my 50cc gasser, i use 22x8 and work perfect. Most of the sport flyers use 7, 8, 10 pitch and 6 or 4 for 3D but as i said depends of the size of the propeller, engine, etc.
Old 11-07-2009 | 10:21 PM
ok let me narow it down I have an RCS 140 on a 2m type free style weighing 12lb. need more vertical i am currently useing a 16x8 APC
Old 11-07-2009 | 10:48 PM
My Feedback: (12)
As a general rule for good 3D performance - vertical performance you want to use the lowest pitch-largest diameter prop your engine will handle. If your running a 16x8 then try a 18x6 prop.
It will give you a slower top speed , but will give better vertical performance. Also try to use a light prop like wood not composite like APC.
Old 11-07-2009 | 11:46 PM
That is what i am leaning toward I have a wood 18x6 master airscrew that i am going to try tomorrow the plane is a model tec remedy a 2m freestyle pattern plane it needs better vertical
Old 11-08-2009 | 03:13 AM
MetallicaJunkie's Avatar
on gassers the lowest is about an 8 pitch.... on glows the lowest is about 4
Old 11-08-2009 | 06:21 AM
My Feedback: (13)
for the gasser's i use the vess A series when i need more vertical.they seem to be like a 6 pitch prop with less speed,but more pull. and i have not been able to find any other prop in a 6 pitch for gasser's.
Old 11-08-2009 | 10:49 AM
Walt and Sage's Avatar
A Vess 23xA works GREAT on a 50cc gas motors for more pull ...
Old 11-08-2009 | 05:39 PM
ORIGINAL: go vertical
I think the APC will have more thrust..if the RCS can swing an 18x6W APC,you should be able to have unlimited vertical and be able to hover a 12 pounder.
Old 11-08-2009 | 06:22 PM
well i tryed the 18x6 today, not good at all it didn't like it at all . tuned the engine in a little better got 8,600rpm on the 16x8 the plane preformed better but still is poor in the vertical just flat runs out after a 200 foot clime
Old 11-08-2009 | 08:07 PM
Eganwp's Avatar
Try reducing some weight in that plane first. A123's/cf lg/lighter wheels/lighter nose cone/lose pilot figure/cf wing tube/remove ballast and move equipment around/smaller tank/etc.
Old 11-08-2009 | 10:14 PM
that for the most part has been done the plane is the plane now i am looking for the most efishent prop
Old 11-09-2009 | 05:58 PM
KWJ48's Avatar
Maybe you need more engine?
Old 11-09-2009 | 06:15 PM
try an apc 17x6 you'll love it
Old 11-10-2009 | 12:58 AM
I thought an RCS140 would have more balls than that. Cant haul a 12 pounder up a short hill? maybe it needs to be tuned better? maybe the 17x6 APC is better. My YS 140 and OS 160 will turn the APC 18x6W with ease and pull around 18 pounds thrust..12 pounds is nothing for them.
Old 11-10-2009 | 12:22 PM
I had this engine on a ultra stick light it weighed 10 1/2 lb. vertical was very good even put the plane on floats wich brout the weight up to 12 lb. it still preformed good that is why i felt ok with puting it in the remedy. i have a 17x6 on order i will try it as soon as i can
Old 11-16-2009 | 02:52 PM
OK the 17x6 was a good improvement
Old 11-16-2009 | 03:27 PM
great....how many rpm's was it turning?
Old 11-16-2009 | 09:48 PM
I didn't get a reading but there is a good improvement in the over all flying .
