twist 40 v2
hi guys i have a twist 40 v2 with a 46 ax engine runnig a 12x 6 apc prop anyone have better suggestion on prop size for hovering it will hover but can barly pull out also anyone have good recomendations for cg got the cg at 5 in back and it wont flatten out in a flat spin any help is much appreciated
PE, CANADA
Honestly you are not going to get a fantastic vertical performance out of a hover on a 40 size plane with a 46 in it... The twist 40 v2 has a weight (obtained from horizonhobby.com) of 5-6 lbs... if you want to get into 3d with it i would suggest getting a slightly bigger motor such as an os 55ax... it has the same mounting dimensions as the 46 and its inexpensive but it will allow you to spin a larger prop increasing airflow over your control surfaces... It will also make hovering easier. When you are hovering you are in a stalled position and are controlling the plane from the movement of air being pushed by the propeller over your control surfaces... a larger motor swinging a larger prop increases prop wash therefore giving you more control in a hover.
Regarding cg...I always spend some time messing with it until the plane flies upright and inverted without any elevator input (or very little). That seems to be a pretty good starting point I think. another point is that you should also laterally balance the plane...
I'm running a Saito 82 with a 14X4. It hovers and powers out with power to spare. It's a bit nose heavy for flat spins, but I haven't done anything to move the CG back.
[youtube]http://www.youtube.com/watch?v=IQJSwf_Lgxo[/youtube]
My Feedback: (22)
IN
ORIGINAL: davidgeorge212
Thats what I use is a 12.25x 3.75
I also have tried a 13x4
CO
I have a twist 40 with a eflite 60 with a 15x10 prop, It has lots of power, but to get this thing to hover, I had moved my CG back 5.5" and change prop size to 16x8. Very fun plane for 3D
