Advice me: hitec 965 MG on 30% scale 50cc
Howdy all:
Well what ya guys think, are the hitec HS-965MG enaught for a 30% (pilotRc yak54 on a DLE 55) for nice 3D performance??
My idea is to use 1 on each aileron, elevator and 2 on rudder. Operating with a 6v system. Reason is cause i got those servos lying around
Here are the servo specs:
Operating Voltage: 4.8-6.0 Volts
Operating Speed (4.8V): 0.13sec/60° at no load
Operating Speed (6.0V): 0.10sec/60° at no load
Stall Torque (4.8V): 119 oz/in. (8.6kg.cm)
Stall Torque (6.0V): 144 oz/in. (10.4kg.cm)
Motor Type: Coreless
Potentiometer Drive: Indirect Drive
Bearing Type: Dual Ball Bearing
Gear Type: 3 Metal Gears and 1 Resin Metal Gear
Dimensions: 1.55" x 0.78"x 1.48" (39.4 x 20 x 37.8mm)
Weight: 2.18oz. (62g)
please advice me....cheers!!
dan
dan
My Feedback: (13)
1 Post
RE: Advice me: hitec 965 MG on 30% scale 50cc
How does the square inch size of the control surfaces compare to the torque output of each servo? One rule of thumb I have read is 1 ounce per 1 square inch.
marginal huh?.....yeah was kinda thinking that too....altho I've seen peeps with planes like this of 30% scale with 10kg servos on ail elev. Decisions decisions.....I guess I'll hav 2 giv it a try [>:] hehe
dan
dan
