what are your best stunts? >
Old 07-26-2003 | 02:08 PM
JohnVH's Avatar
My Feedback: (38)
Default what are your best stunts?
hehe, I let the cat out of the bag, dont tell him I said it!!
Old 07-27-2003 | 01:18 AM
C'mon John give us some stick moves to make our planes look good
Old 07-27-2003 | 01:20 AM
JohnVH's Avatar
My Feedback: (38)
Like I have stated before, watch my vid, and ask how its done.
Old 07-27-2003 | 01:26 AM
Watched your video John tell us what we saw and how to do it. If I knew what each one was I would not be asking.
Old 07-27-2003 | 01:27 AM
JohnVH's Avatar
My Feedback: (38)
well, I kinda need to know which one your asking about. Probably need to make some 3D vids with talking on what Im doing as its flying someday
Old 07-27-2003 | 01:30 AM
  #31
That (Video and desciption)would be a very good thing to do for us John but why not go through what you did on the tape and tell us what each one is called then we can ask how to do it.
Old 07-27-2003 | 01:39 AM
  #32
JohnVH's Avatar
My Feedback: (38)
1.on take off upline I just kept full throttle, and put full left aileron, full left rudder, and full down elevator.
2.Second manuever was the tip spin
3. same as 1, except off a 45* up
4.blender
5.knife edge
6.Elevator into harrier into torque roll
7.#1, then went into a waterfall
8.Elevator into harrier
----Music change----
9.4 point roll
10.stall turn
11.rolling circle rolling to the outside
12. vertical stall
13.Wall into a torque roll
14.4 pt roll again
15. vertical stall
16. #1
17.the landing
I think I got it all in order..
Old 07-27-2003 | 02:29 AM
  #33
John , how do you perfrom the 'tip stall'
Old 07-27-2003 | 02:47 AM
  #34
JohnVH's Avatar
My Feedback: (38)
Here, there is a thread in this same forum on it.
http://www.rcuniverse.com/showthread...67&forumid=230]
Old 07-27-2003 | 04:19 AM
  #35
Knife Edge Spin (post # 1)
Could anyone explain tis manouver for me , and how to achieve it?
Thx
Report this Post To RCU Moderator Team | IP: Logged *
07-26-2003 6:13 PM
JohnVH
cm
Offline
Discussion Post Total: 5350
(post # 2)
1.Get alot of altitude
2. do a knife edge, or as the model almost stalls tip some rudder so it falls onto its side from the vertical climb
3. Give full aileron in the same direction of the rudder, which should be up if your in knife edge, and full down elevator
That should make it go, to wind it up a bit put a touch of throttle in it.
To exit
Either let go of the controls and throttle to idle
give opposite rudder for an inverted flat spin. Then release controls to exit the flat spin
The manuever can be done from a blender, or turned into a blender and back and forth
Does that make any sense?
You can watch my super sukhoi vid, I do a couple in that too, its on my prop site below.
__________________
Prop movie website
Jet website
ProBro#20
07-26-2003 7:17 PM
obi1
Offline
Discussion Post Total: 143
(post # 3)
Thanks , so let me try understand.
Flying right to left i start knife edge , with left aileron ( canopy facing me ) holding with right rudder.
Then add full right rudder,full right aileron and full push elevator.
This correct?
07-26-2003 9:14 PM
JohnVH
cm
Offline
(post # 4)
Well, lets say your in a knife edge flight from left to right, you will only be using left rudder to hold your altitude. Cut your throttle to idle and as it slows down keep adding left rudder to hold it in knife edge. Once it pretty much stalls, add full left aileron, full down elevator and full left rudder. It will tumble a sec then should go into the spin, give a bit of throttle to spin it up a bit.
Then the flat spin entry is simply hold all sticks where they are, and add full right rudder then slowly reduce the aileron as necessary.
Hows that?
__________________
Prop movie website
Jet website
ProBro#20
Old 07-27-2003 | 04:22 AM
  #36
Thank you very much John now I can see what is what hope you dont mind I copied part of the link you posted to this forum. It all makes sense being able to watch your video and count off the manuevers. You are a very good pilot keep up the good work and share the fun.
Old 07-27-2003 | 04:41 AM
  #37
JohnVH's Avatar
My Feedback: (38)
Thanks, one of these days Ill get together with Flyfalcons and maybe some other 3D guys and make some manuever movies like we did with the IMAC sequences.
Old 08-02-2003 | 11:33 PM
  #38
My Feedback: (16)
My best stunt has to be landing. lol. Just kidding.
Old 09-08-2003 | 08:31 PM
  #39
Default RE: what are your best stunts?
Anybody got sometihing to add I am flying a goldberg sukhoi now so keep that in mind
Old 09-09-2003 | 05:02 PM
  #40
i have a question. i have a 26% dave patricks extra 330L. it has a ts 52 gasoline engine on the front. it flys great and has plenty of power. it does flat spins nice upright and inverted. it will also torq roll really well. the question i have is about the harrier. when i put it in a harrier it start out in an elivator and transition into level flight. on the way down it does fine but when i try to level out the wings start rocking. i can use the ailerons to try and keep it level and it works but sometimes it gets out of control. do you have any advice ie. setup or anything els.
thanks willy
Old 09-09-2003 | 06:33 PM
  #41
Latelly I have been doing something I have wished for a long time. Land from a flat spin, prop spinning, take off again. I am doing it with my 40%CAP..... Yeahh, sure, doing with my SPA3D and 46 mousse pipe. Sometimes it bend the tail gear a little, but no major hassle.
People simply go wow.. hes got the guts... and a very ugly plane...
Old 09-09-2003 | 07:47 PM
  #42
JohnVH's Avatar
My Feedback: (38)
3-d. Mine rocked a bit, I just moved my CG way back, now I can harrier land it it got so stable.
Use your ailerons for the rocking, and rudder to steer it and throttle for altitude.
Ill get some harrier landing vids next time out!
Old 09-10-2003 | 04:37 PM
  #43
thanks for the help. i already have the cg back about an inch from what they recomended. should i go farther? should i mix up or down flaps with up elivator. i heard that that would help.
willy
Old 09-10-2003 | 04:41 PM
  #44
"Latelly I have been doing something I have wished for a long time. Land from a flat spin, prop spinning, take off again. I am doing it with my 40%CAP..... Yeahh, sure, doing with my SPA3D and 46 mousse pipe. Sometimes it bend the tail gear a little, but no major hassle.
People simply go wow.. hes got the guts... and a very ugly plane... "
is that really posible. how did you get your spin flat enugh to land without damaging the plane. is there a video or pictures of this. i would love to learn how to do that.
willy
Old 09-10-2003 | 08:45 PM
  #45
dirtdr's Avatar
ok it wasnt in the vid, but i have been trying to do a KE spin with my lanier edge 540 1.20. I did it one but by accident and havent been able to to it again.
the one time i did i, i was trying to do a blender i think..
Old 09-11-2003 | 06:37 PM
  #46
cabanestrut2002's Avatar
i have been doing flat spin landings lately aswell.
they look very good when the prop doesnt strike, it need to be still air to stop the tail lifting before touchdown-if its windy it sort of bobs up and down, thats when it can catch the prop on landing.
its very satisfying when theres a little wind and you judge the start position just right so it lands in the middle of the patch with the engine still running. takes practice though.
i hate when i go dead stick in a flat spin, i have no choice but to flat spin land then coz the fin needs the propwash to get 'working' again! the model i am flying doesnt come out of a real flat spin dead stick!!
