RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Customized Chip Hyde Vision 3D! (https://www.rcuniverse.com/forum/3d-flying-82/2749394-customized-chip-hyde-vision-3d.html)
NE0 03-10-2005 12:17 PM
1 Attachment(s)
Hiya guys, just finishing up my Chip Hyde V3D and thought I'd share some of my "custom" mods. Still waiting on my prop, but here's some pics of my covering scheme. I stripped the stock covering off completely, made a few internal mods, and recovered with a scheme of my own design. First I'll show some pics of the finished covering scheme, then I'll discuss the other mods I did.
Tom
Here's my ugly mug with my V3D. As you can tell by the grass, it's not quite flying weather yet... 20-30 degrees and snow is coming tonight... again!
NE0 03-10-2005 12:21 PM
RE: Customized Chip Hyde Vision 3D!
1 Attachment(s)
Here are a few more views, giving you most of the angles of the scheme.
Tom
NE0 03-10-2005 12:25 PM
1 Attachment(s)
I designed all graphics in Adobe Illustrator and Photoshop first. All covering was cut by hand in Ultrakote. Logo graphics were cut by my buddy Dave "Maudib" Johnson on a vinyl cutter (Thanks Dave!).
Tom
NE0 03-10-2005 12:29 PM
1 Attachment(s)
Canopy was blacked out from the inside with Krylon Fusion paint. Outside was trimmed with Ultracote Red paint.
Cowl and wheel paints were also painted with Ultracote. Of course, everything had to be sanded down, primered, painted and clear-coated.
Ultracote clear works great on colors, but be careful on white... it slightly yellowed my white paint, but not badly enough to strip and redo it! ;)
Tom
whayden2003 03-10-2005 12:40 PM
man that thing looks great. chip should have called you to ask for ideas on the first scheme....
NE0 03-10-2005 01:38 PM
1 Attachment(s)
Thanks! Glad you like it. :D
Here is some more info on my build...
I used a DA50 for power with a stock DA muffler. Had to cut the crap out of the cowl, but it doesn't look too bad. Servos are Hitech 5945 all the way around, except for a 475HB on the throttle and a 5995TG on the rudder.
I used carbon fiber landing gear, spinner and tailwheel, a 1400mah Nicad on the ignition and will use a Lithium pack for the Futaba PCM receiver.
I've got a SmartFly regulator/Miracle switch with a pushrod adapter on the switch, mounted just over the wing.
Lightweight tires came from BME Aircraft, and are extremely light at 2.45 oz for both wheels!
I used a Hobby Lobby hatch latch that was epoxied into a recess in the styrofoam turtle deck. The release pin was removed and Loc-Tited back in with an aluminum sleeve extension added.
Tom
NE0 03-10-2005 01:47 PM
1 Attachment(s)
Here's the canopy mod. I also blacked it out from the inside with Krylon Fusion black spray paint. The outside of the canopy was trimmed with Ultracote red paint and clear coated.
Since the canopy was blacked out, I decided to cut out lightening holes int the canopy hatch framework.
The tank was moved to CG, mounted under the wing tube and can be removed through the hatch if needed.
The choke was finished by adding an aluminum servo arm on the choke armature, then a pushrod was extended back into the canopy hatch area.
Here is a shot also of the carbon tailwheel, with the tailwheel/rudder linkage. I added a wood block inside the rudder at the bottom to run the bolt through the rudder for the tailwheel springs.
Tom
NE0 03-10-2005 01:55 PM
1 Attachment(s)
OK, back to the beginning. After stripping all the original covering off, I found a few issues that I decided to modify...
1) The hinging. I didn't get a "warm and fuzzy" feeling about using the supplied CA hinges on a bird this size, and the stock hinge slots were double-cut, crooked and just didn't look sound to me... so I opted to go with Robart Hinge Points.
Unfortunately, there didn't appear to be enough balsa in the LE and TE of the surfaces, so I had to add some. I cut out areas in the sheeting and installed some balsa hinge blocks at all hinge points of all flying surfaces, drilled them out and installed the hinge points.
2) Next, I found over half of the ribs in the both wings to be broken. However, they had obviously been broken during construction and glue applied to strengthen them back up. They seemed solid, but reminded me of a broken bone that had healed without ever "setting the bone" before healing. Healed in a crooked/disjointed position. So, I didn some rib scabbing to fix this issue before covering the wings.
3) Lastly, I decided to add some balsa tri-stock in critical areas around the formers from the canopy back to the tail. Not much, just a litle added support for such a light-weight build.
Tom
LBKinchlow 03-10-2005 06:45 PM
Hey Neo great looking plane, I've drawn a design of my own on paper and trying figure out how to transfer it to the plane. but was wondering how you set up your Illustrater to match the plane
NE0 03-10-2005 07:10 PM
1 Attachment(s)
I took 3 photos of the stock V3D into Photoshop first... Top, bottom and right side views. I cut them out of the backgrounds and paint the planes white... this is your base. Now, using layers in Photoshop, I design the overall color/graphic scheme, right in Photoshop, not Illustrator. Once I'm happy with the overall scheme, I then go to Illustrator.
In Illustrator, I design all the logos, text, etc. and save them as EPS files. Now I go back to Photoshop and load the EPS logos in (rasterizing them) in PS. Now you bring those rasterized logos into your main Photoshop file as layers. You can scale, duplicate, reposition, etc. in Photoshop to position them on the different views of the plane. Before you know it, you've got your final, completed design.
Next, I print out a copy of my 3 Photoshop views and use it as a guide to hand-cut the Ultracote when covering the scheme. For the logos and text, I send the original Illustrator EPS files (vectored art) to the vinyl cutter, and tell him what size to cut them at, what colors, etc.
To figure the size of the vinyl graphics, you refer back to your Photoshop printout, measure and scale accordingly. For example, if the Vision wing is 40" long, and the same wing is 4" long on your print, you know your scale factor is 10%. So if the wing logo on the print is 1/5" long, you take that times 10 (15" inches) and tell the vinyl cutter that the logo should be cut at 15".
You only need to give him one size of the logo, then tell him what different sizes you need it cut at.
Here's a copy of my original V3D scheme done in Photoshop, with the Illustrator logos added into it. I modified it a little when I actually put it all on my plane, but overall it's pretty much the same design.
Hope this helps,
Tom
NE0 03-10-2005 07:13 PM
Sorry, correction to above post:
If the logo on the print is 1.5 inches long, then your factor of 10 puts you at 15" for the vinyl logo.
(1.5 inches, not 1/5 inches)
Tom
mvigod 03-10-2005 07:23 PM
Tom,
This is fantastic. Not only the mods on this plane (I'm going to be putting one together myself soon) but the info on how to create your own scheme. Great pics and illustrations. Wish I had your talent with this stuff...you are GOOD!
Question. When cutting the custom scheme and using the illustrations as guide it would seem "straighforward" on flat surfaces like the bottom/top of the wing but what about wraparound areas like the fuselage side/top? Since there is a foldover on that surface what do you do to compensate for compound curve areas?
NE0 03-10-2005 09:41 PM
Marc,
Thanks! Great question. [&:]
What I do is get some large sheets of paper and wrap them around the area to be covered on the plane, taping them in position with masking tape. I have connections at a local printing company, so I can get large rolls of scrap paper easily. You can use rolls of butcher paper or even the backside of gift wrapping paper. Once you have it taped into position, you "draw" your designs onto the paper, right on the plane with a pen or marker. This allows you to position the intended graphics over the compound curves.
Next you just pull the paper back off the plane and tape it down on a table over your covering material, and cut right through it with a razor knife into the Ultra/Mono cote. It's kind of like tracing, only backwards. Lay your master sketch on top and cut through it instead of laying it underneath and tracing.
This procedure gives you accurate templates that consider the compound curves in the equation. For example, a 1 inch wide strip going around the front end of a cowl would not be a straight line if you pull it off and lay it on the table. It will bend and curve in different directions to "seem" straight when it's on the plane. By doing this on paper taped to the plane first, you find out what and where those curves need to be. Then it's just a matter of transferring them over to your covering material and cutting it.
Whala!
Tom
NE0 03-10-2005 09:53 PM
One other thing regarding my "mods"...
I just used a borrowed prop and battery to check my CG [:'(]
I'm coming up extremely tailheavy and may need to add as much as 3/4 pound to the nose to balance! [:@]
How and why? Not "entirely" sure but here are my thoughts...
1) I used the 1-1/4" standoffs, some are using longer standoffs, pushing the engine weight further forward. But some are using the same standoffs I did....????
2) By replacing the stock CA Hinges with Robarts, I added the weight of the Robart Hinge points, AND the weight of the balsa hinge blocks and glue... waaaaay back there in the tail (as well as wing TE). I may have added as much as 1-2 ounces to the tail doing this now that I think about it. That's a 4:1 ratio from tail to nose for balancing, so 2 ounces in the tail means 8 in the nose to balance.
3) I used Carbon Fiber landing gear and spinner, so I lost about 4 ounces in the front end that I'm going to have to add back in now.
4) Maybe an extra ounce or two of covering and viny graphics from the CG back that aren't on a stock plane... that means another 2-4 ounces needed up front to balance.
CRAAAAAPPPPPP!![:'(]
BUT, this is all based on the "suggested" CG point. From what I hear, some guys say their V3D's are nose heavy (which is why I wasn't originally worried about tailweight). If in fact I can move my CG back some from "suggested" point... maybe I can get away with about 1/2 as much ballast in the nose.
Without ballast, I'm at 16 pounds even. So it looks like I'll be at 16-3/4 pounds on the maiden. If she doesn't feel tailheavy, I can slowly remove ballast until I reach the "danger zone" ;)
Oh well, even at 16-3/4 pounds, that's a lot lighter than my last plane (WH Edge with a BME 50) and this plane has more wing area. My Edge was 18-1/4 with Smoke and about 17-1/2 without smoke... still flew great. Also, the Double Vision is around 17-1/4 pounds and is a rocket on a DA50, so I'm at least a half a pound lighter "with" ballast. Should be fine.... we'll see.
Tom
drumbum 03-10-2005 10:12 PM
Beautiful work! love the color layout.. looks like your a perfectionist like Maudib. he also does beautifull work..
bet you guys take off and land on putting green, true chem treated grass;):D
NE0 03-10-2005 11:35 PM
Thanks for the compliment. Yes, Maudib is the man ;) Actually I do all my building at his shop and he's the one who pushes me to higher levels... could never do it without his help! [8D]
Tom
mvigod 03-10-2005 11:44 PM
ORIGINAL: drumbum
Tom is actually an extreme perfectionist...read this article in the RCU Magazine as he takes the top prize at toledo in the static competition w/his dauntless!
http://www.rcuniverse.com/magazine/a...article_id=328
LBKinchlow 03-13-2005 03:06 PM
Thanks alot hope to post my new design soon
[8D]
MarkNovack 03-13-2005 03:36 PM
I tell you, I have a DV and think its a pretty airplane. the V3D however, I found kind of "not so pretty"...bordering on volvo functional looking (no doubt is flies superbly). Your scheme, however, have transformed the unsightly lines and enhanced only the elegance of the length and volume. Great job. All it took is the right scheme.
Fastlif 03-13-2005 04:14 PM
looks great man. you could change tail gear to carbon, put the stock main gear back on.? that would help.
NE0 03-13-2005 05:18 PM
1 Attachment(s)
Thanks guys, yep the stock scheme just was not doing it for me. I really think this scheme is a major improvement to an already awesome ship.
Fastlif,
I already have the carbon tailgear. As for the carbon main gear, I thought about that, but it's so close to the CG that it would kind of be a wash. Adding a few ounces that close to the CG by using the stock gear instead would only save me half that much balance weight from out on the firewall.
You end up saving an ounce or two of lead ballast by adding 3 or 4 ounces in the gear. So, you've then increased the overall weight and pretty much lost all your savings. Yes I'd have less lead on the firewall, but my AUW would actually be higher since my lead is further forward of the CG than the main gear are.
Besides, them carbon gear are just to purdy! ;)
BTW, I just finished moving all the radio gear and throttle servo to the CG or forward of it, and mounted all my little lead bricks to the firewall and cowl. With 13 ounces of lead up there, I'm balanced at 1/2" behind the suggested 3-1/4" CG point. I'm going to fly it like that and see how it feels.
If it doesn't feel tailheavy, I'll start knocking a couple ounces at a time off the firewall and see how it feels. I may find that I can actually lose 6 or 7 ounces and still be at around 4-1/4" CG, and fly great. If so, I'm just fine with having it at 16-1/3 pounds as long as it performs. That would still be 2 pounds lighter than my WH Edge was (w/smoke)...Wish me luck ;)
Tom
Fastlif 03-14-2005 08:41 AM
Cool, please post on how it felt to fly it at your current cg. looks like some work to get that stuff forward. I know one thing I do not like is installing the fuel tank on this plane, I hope I never have a problem with it.
did you get your carbon gear from troy built models?
I know if I was to do it again, I would use regular size standoffs, heck with the 1.25's. the cowl would of fit better and it would have saved the cg hooplah. Mine is at 4.25 inches cg, I believe it will fly fine, but waiting for the snow to melt. maybe this sunday if its nice out all week. California dreaming.
NE0 03-14-2005 11:01 AM
Yes I got my CF gear from TroyBuilt. I agree on the standoffs, that would have mad a huge improvement on CG. Too much work to change it now though. If push comes to shove, I can move the carbon spinner off to another plane some day and put an aluminum spinner on this bird. That would add a good 2oz or more all the way out on the nose and probably save me an 4ounces of lead from the firewall. Net savings would be about 2oz. Would that really change the way it performs? Probably not enough to warrant it at this time. But if I need that CF spinner for another plane some day, then maybe that's the time to do it.
I don't know if I'll get to fly mine any sooner than you do... I'm in snow as well. 22 degrees outside today, and still snow and slush on the ground [:o][:'(]
Got my prop today, once I drill it, I'm going to paint it to match the plane's scheme. I'll post pics when I do. Got all my rates, expo, etc. set up in my radio last night. Other than the prop, nothing left but range check and run in the motor! :D
Tom
NE0 03-14-2005 07:46 PM
1 Attachment(s)
OK, got the prop all drilled and painted... really turned out nice. I used an MSC 22x8 wooden prop, drilled out the holes and lightly sanded it. Then I designed the prop "scheme" in Photoshop and the vinyl logos in Illustrator.
I covered the front side of the prop with Artists Airbrush Frisket Film and drew my color scheme onto the film. Next I used a razor knife to cut away the mask for the black areas, and shot it with Krylon Fusion black. Once dry, I swapped mask areas to shoot the yellow and red areas with Ultracote paint. Once all was dry and mask removed, I applied the vinyl logo and prop size text, followed by a few good coats of Ultracote clear.
I then put it on a prop balancer and found one side to be a tiny bit heavy. So, about 3 or 4 more light coats of clear on the "light" half of the prop and it balanced right up perfect. I checked the weight before and after painting and the weight gain barely even registered. After drilling, painting, clear coats and balance, it still only weighs 4.75 ounces. My other unpainted MSC props weigh 4.8 ounces! Yes, they are already drilled, so the only difference is the paint.
Here's some pics of the prop on the V3D... just the right touch ;)
Tom
Fastlif 03-15-2005 07:15 AM
Tom,
you have patience, I thought I had patience, but after seeing your prop, nah, that is awesome. Your plane looks great, mine is all stock, looks like crap compared to yours, so I took a sledge and smashed it. haha. no, really though, your plane looks great, and after working with this Chinakote on mine, I fully agree in recovering. I wish Chip would goto Ultra/Monokote. I do not know if the new versions of the V/DV are covered in it or not, but sure wish they were, I am thinking of buying a Doublevision, but am thinking of recovering it in my own scheme.
well snow is melting, slow but sure. Should be soon that we can fly. I sure hope so.
NE0 03-15-2005 09:10 AM
Fast,
Thanks! I agree on the covering, and I think if you asked him, Chip probably wouldn't disagree with you either ;)
My buddy has one of the new DV's sitting here and it looks like the same covering. Actually, I liked the original DV scheme better, but this one is OK. He made definite improvements in the cabane structure, but looks like the covering is the same ol' same ol' :eek:
Hopefully all will go well with my range check and running in the motor soon... and... warm weather soon! :D
Happy flying!
Tom
Fastlif 03-20-2005 09:37 AM
Tom,
Flew my Vision yesterday. All be it brief, the motor was giving me fits. I got two hops on it, with two dead stick landings. Last time I ran this 50 was last fall, ran perfect, I put some marvels mystery oil in the cylinder for winter, and that fouled the plug at first. I replaced that got it to fire, then it would not transition to full rpm. So, took off cowl and fiddled, richened low end and high end a touch. Seemed to be spot on, but once in air it was a tad rich, and would quit on me after some tumbles and snaps. O well, I got to fly it, it flys light, it really does compared to my Katana. From what I could feel I really like it, real comfortable with it. It was about 40 degrees so a bit cool, runway was mud, plane came home covered. So it will not be going back till ground is hard and motor is tuned perfect at my house.
Just thought I would pass that along.
Jim
southern_touch9 03-20-2005 10:27 AM
I say if you have to add the kinda weight with the recommended engine then there is a definate problem. If you wanted to balance it without adding the weight you could always relocate where the wing joins the fues. Move the wing back. You have spent a lot of time on this plane, and a lot of money on CF upgrades I would hate to see you have to waste all of that by adding dead weight.
Moving the wing back is how TBM fixes the tail heavy problem with the H9 Sukhoi so talk to Gene and he could walk you through it.
NE0 03-20-2005 11:10 AM
Thanks for the flight report Jim, sorry about the engine problems. I blew my entire flying season last year fighting a BME 50 that way... turned out to be 2 bad ignitions, but the season was over before I figured it out and got it fixed. I better not have those problems again this year with my 2 new DA's. I gotcha with the cold and mud... my field is the same way, which is why I'm not joining the club "snowbirds" down there yet. I'll wait for better/drier weather. ;)
Layne,
Thanks for the suggestion but there is no way I'm going to that much trouble to save a the weight. I'm confident that I'm going to be able to knock at least 4 ounces of lead off of it and still be in good flying shape. I also managed to shave another ounce off of the canopy, so I think I can fly at 16-1/2 pounds. That is NOT heavy for a plane this size, with this much wing area and a DA50. It's simply not worth all that work to move the wing and risk screwing something up on a perfectly good plane. As I mentioned before, my Edge last year flew great at almost 2 pounds heavier, less wing and a weaker engine.
You have to remember, that I added that much weight due to the tail mods I installed, and the nose weight I "lost" due to the CF stuff. Let's say I didn't use the CF stuff... The bare weight of the plane would go from 16.0 pounds, to 16 pounds - 5 ounces. So if I come in balanced now at 16'8... I'm only 3 ounces heavier than it would have otherwise. That's not a big difference and justifies the "insurance" I have of knowing that my surface hinges are secure. OK, so I replace the CF spinner with an aluminum one... I lose 3 ounces of lead, but gain 2 ounces in the spinner... net difference of only an ounce. Not worth it to me.
I think guys get WAAAAAY too caught up in the numbers. 16 pounds, 16.2 pounds, 16.5 pounds... what difference does it make as long as the plane performs to your satisfaction? The plane doesn't know how much it weighs. :) Any plane with this much wing area and a DA50 at only 16.5 pounds is still going to have extremely high performance... certainly enough for a rookie like me. ;)
Tom
southern_touch9 03-20-2005 11:25 AM
True that numbers are sometimes deceiving but Imagine how it would fly at 14.5lbs. BTW do you still have your WH, I am trying like heck to find one of this used to strip it down and do somewhat of the same thing that you did to the vision.
NE0 03-20-2005 11:36 AM
14.5 pounds!!!!! Why not imagine it at 12 pounds, cause you got about as much chance getting it to 12 as you do 14.5 pounds. What's the point in imagining that when you ain't never gonna get there? ;)
If I took off all my nose weight, I'm at 16 pounds even. Take off maybe 4 ounces max for all my mods (except covering) and you're at 15.75 pounds. My extra graphics and covering net no more than 4 ounces over the stock scheme, wich would be 15.5 pounds... minimum. NO WAY you'd ever get another pound off of this plane... and, that is "with" CF spinner, landing gear and tailwheel. Without all the CF stuff you'd be back up to 15.8 pounds. 14.5 is a pipe dream.
No I don't have my WH Edge anymore (which by the way weighed 17.5 pounds with the stock scheme). I sold it a few months back to fund the Vision.
Tom
southern_touch9 03-20-2005 12:44 PM
Lets work down from 15.5 to 14.5 That means we have to shave a pound
At 14.5lbs the BME 44 would be the right motor
Switch to BME 44 ---> Save 4.8 oz
Replace the NICAD ignition battery w/ Li-ion ---> Save 1 oz
Take off spinner ---> Save 2.2 oz (you will get more useful area out of your prop)
Drop those wheel pants ---> Save (guessing here) 3 oz
Thats 11oz off the top of my head but Im guessing that holes could have been drilled in the motor mount/motorbox area
Would I have gone to all that trouble?? NO :D But where theres a will theres a way my brotha
NE0 03-20-2005 01:17 PM
I think I'd have to disagree with you.
"At 14.5lbs the BME 44 would be the right motor"
That's a wash. Lighten the plane, the put a MUCH weaker motor... you're getting a "little" less wing loading, but at swinging much less prop/power.
"Switch to BME 44 ---> Save 4.8 oz"
Sorry, but you'll need that 4.8 oz to balance
I don't like Li-ons, but again, you'll need that ounce for balance.
"Take off spinner ---> Save 2.2 oz (you will get more useful area out of your prop) "
Sorry, not my style. All the work to make this plane look beautiful and then run it without a spinner? UUUUUUUUGGGGGLLLLLYYYYY!! ;)
AGAIN, need it for balance.
Another aesthetic issue. If I were going to do that, why would I put all the effort into making it look good... plus that's ahead of the CG too.
"Thats 11oz off the top of my head but Im guessing that holes could have been drilled in the motor mount/motorbox area "
Yeah, and that's 11oz all ahead of CG. Sorry but you would never balance this plane with 11 oz taken off the nose... at any weight. Might as well take the motor off and save 4 pounds... heck then we'd have it at 10 pounds! It would fly just as good as it does with a tailheavy 11oz off the nose.
Tom
southern_touch9 03-20-2005 02:55 PM
well...I wouldnt have added the tristock that far back either ;) and moved the wing to balance
Im just not a big spinner fan. At one time I put a spinner on everything but one day I questioned Quique after watching him fly a demo on why none of the planes there have spinners and he told me it takes away from the prop, I tried it and you can tell a difference. I ALWAYS have a performance over looks kinda mindset. If you can make it look good without adding weight then its a bonus.
However that is a great job at covering the plane, I need someone to cover my next one for me [8D]
NE0 03-20-2005 03:47 PM
Hmmm, that's interesting about the spinner... never woulda imagined it had an effect on performance! [X(] Oh well, I understand your performance over looks point... but I'm one of those guys that's a little more the other way around. ;) As a big scale nut, my planes have to "look like planes" if at all possible and I LOVE the real good lookin' ones. Don't get me wrong, I don't believe in making it look good if it also makes it perform poorly. But this plane will NOT perform poorly. I'm just not going to destroy it's looks to give it 5 or 10% better performance. It will be more than enough for me as it is, and waaaaay better than anything I've ever had. ;)
Besides, I've also got an EF 87" Yak that should come in at 15 to 15.5 pounds. Now THAT plane will be a performer for sure. So if I've got one that looks "OK" (Yak) but performs "extremely awesome" then I'll have another (Vison) that performs very well, but looks "Awesome." They don't ALL have to be the best or the same. Some look better and some perform better... as long as NONE of them perform like dogs. :D
Tom
Fastlif 03-20-2005 05:54 PM
Tom,
Yeah, my engine troubles were just lean on the low, and high, I richened it, and seemed good on the ground, but after flying, under load it did not like it when dropped to idle during yanking and banking. This motor was perfect last summer for me, I love DA and think there is no better on the market right now. I will buy DA forever, long as I am running gas. I got some time on it though, so all was not lost. It fly's light, and you know I do not even know the weight of it, I would guess right around 16.5, but thats a total guess. I will have to weigh it next time I put it all together. I would not sweat the weight too much on yours, I know what everyone is talking about, lighter flies better I know, I come from Fun Fly competition, where 2.5 lbs is fat. So yeah, I know all the games, but really this big plane stuff is a nice break from being so anal about weight. The new EF yak looks promising, my fllying buddy has one on order, and I may order one once I twiddle the sticks on his, but it should rock. I like the Vision/DV and like the way they both fly.
Only mods I plan to do to the Vision is Carbon wing tube, which Gene at TBM will have next week, and a carbon rear gear, the stock one is junk, did not make it thru the day yesterday. My friend had the same problem on his DV last summer. Beyond that, I just want to fly. Prolly will not be til after Toledo though, the ground is just a mess.
NE0 03-20-2005 06:31 PM
Yep you will love that Yak. I've got one sitting here still in the box. Got the servos, engine, etc... but haven't started it. I've also got a DV in the box but nothing to go in it. Those are 3 of the best 50cc planes available today, so I should be in good shape once they are all done. ;) My buddy Dave (Maudib) flew his DV at our field a lot last year and that thing was amazing. Mine is a "scratch and dent" so I have a couple minor repairs to make but nothing serious.
Hopefully I'll have good luck with the DA in my Vision... all the ones at our field run flawlessly. Seems like I'm always the guy that gets the "odd" one that doesn't :)
Anyhow, keep me posted on any further flights and I'll do the same. Like you, I doubt I'll get up until after Toledo. Between snow, cold, mud, and I'm also having some battery issues to straighten out first... well, not gonna happen this week. My Li-On pack is not cycling properly, so I'm trying to find a better pack for it. Don't want to risk this puppy on a questionable battery! [:-]
Cya,
Tom
southern_touch9 03-20-2005 06:47 PM
I flew the 87" EF Yak about a year and a half ago when it was in its prototype stage. It flew great, I have the smaller yak now, I have a few issues with it but as soon as I put a different motor on it Im sure I will like it too.
NE0 03-20-2005 07:32 PM
Coolio. [8D] Maudib had the smaller one too, and it was awesome. It was the main reason we got interested in the 87" version over a year ago. That thing would do pretty much anything you asked it to without any bad tendencies. Sweet bird. [sm=thumbup.gif]
Tom
Eric.Henderson 03-20-2005 11:25 PM
1 Attachment(s)
With the long winter I had time to replace my own ISO mount with a new Hydemount, for the DA-50 in the Vision. It saved me about 4 oz over the B&B iso-plugs.
This is what it looks like.
Eric.
