i bought a flip 3d
bought it today going to put a irvine 53 in the baby....anyone got any hints or tips for building it ????
i bought a flip 3d
I would also like to no as i will be buying one at wings and wheels spectacular. Any building or flying vices?
i bought a flip 3d
The best prop for your combo would probably be an apc 13x4 if you didn't already know. Have fun.
i bought a flip 3d
i have seen flips and they have the most awkward stall characterisitc ever, this I think is due to the wing tip shape. Power off they're a disaster.
Don't waste your money, get a 3Styla from RC World. Yes, I am on the RC World Display Team, and will be flying them at Wings n Wheels, but I first flew one at Weston Park last weekend in our display slot, and no joke, it really does p!*s all over any other similar size 3d model i've flown It is far superior to the Hype, which i'm informed is far superior to the flip. Needless to say, i'm well impressed. No doubt you think I'm biased, but I recommend that before you buy your flip you watch the 3styla in action! Kits available at www.rcworld.co.uk |
i bought a flip 3d
The Irvine will be a great combo, but use 12.5 X 3.75 APC prop. Strenthen the tail don't use the wire, I've used carbon rods. Peg the hinges, I used the Great Planes fibre, put extra on the Rudder. If flying from grass dump the spats. The book settings are LOW RATES. Fly one to get hooked.
i bought a flip 3d
johnyh thanks for the advice ive got plenty props that you recommend you also say dont use the wire why not ???
just curious.... how does the 53 do in the hover whats the escape power like?? thanks miskin |
i bought a flip 3d
13x4 on the Irvine goes great guns, quick spool up and nice braking for constant speed. The Irvine is a very solid performer, you will get plenty left to escape from nasty hover fall-outs and to start the TR. I feel now I should place a shameless plug here for SuperGlue or a kit.... ;)
http://www.probuild-uk.co.uk Hehehe... simply the best for what I do, anyway. |
i bought a flip 3d
Miskin I felt that I needed a rigid back tail end, from experience from with myExtra Wot. The wire were to flexible. This was noticed when trial running on the ground and watching the vibration flexing the back end. Today I was hovering with the ASP 53, similar to the Irvine I have both, by blipping managed to get down to half throttle, plenty left for flyaway. Incidently I have replaced the under cart with a wire set up from an old panic.
i bought a flip 3d
I saw two more flyign today with irvine 53s and thye flew far betterthan those with Yss, it's definately the way to go
i bought a flip 3d
ok guy's i flew my flip yesterday for the first time brand new irvine 53 12.25/3.75 prop 5% nitro .
the problem that i have is when i hover(vertical) about 1/2 throttle and go to power away(still vertical) it takes ages is this normal ??? i was expecting something quicker (like my cougar 2000) shall i try different fuel ive got 10% nitro or shall i try different prop's???? |
i bought a flip 3d
Im gettin a flip with a west 50t1
Should be cool Were can i get some good carbon pushrods? Thanks Ian |
i bought a flip 3d
Miskin Try Duraglow10%. But allow several tanks through and you MUST set the engine up, with a good slow run.
Edible I made my own rods cynoed into brass tubing. Steve Webb at Frodsham, will have the gear. Welsh told you they were/are good, with that set up.Y have an S when there are good 53s? |
i bought a flip 3d
johnyh
the fuel that i have is prosynth 2000 from weston's i have to use that in my west 50t1 for my hype 3d will that be ok |
i bought a flip 3d
Miskin I've seen the pro run but still prefer the Duraglow10% because it's more available locally. Try it and see but 10% seems betterfor the quick responses. But remember the Flip will fly Veerrryyy slowly but you then need max deflections on the surfaces. But the pleasure when you get right to the dismay of club mates.
Carbon Pushrods.
edible engine
try fibre tech (www.fibretechgb.co.uk) i use the 3mm o/s diameter with a 2mm internal diameter as a standard metal push rod fits inside. i cyno it in, then whip 1/2 inch of the carbon rod and 1/2 inch of the metal rod for additional support as i dont trust cyno on its own with metal. a 980mm rod weighs 8.3gr and cost £2.80. |
i bought a flip 3d
Would the Radio active big extended horns do for higher stress loads and movment or should i go metal
Ian |
i bought a flip 3d
Edible I've used the horns supplied. It was my failure to peg the aileron correctly that caused it to part from the wing and not a horn failure. However I do use tubing just to provide tension on the clip.
i bought a flip 3d
Edible ive got the west .50t1 in my hype its only been run twice and i tached it its turning my 13x4w apc prop at 12100 on 10% nitro so im hoping it will get stronger the more i use it...
my hype weigh's 6 1/2 pound my flip weigh's 5 1/2 pound should be great in a flip |
i bought a flip 3d
My advice if you are talking control horns is to go for the sullivan metals with the f/g inserts that stop slop. They are very very strong, look pretty cool, don't weigh a lot and sure can handle the stress. failing that the MK's or ZN hors go great. Pricey I agree but worth the investment. After all when the plane turns to dust on an impact, rest assured you can recycle those bits. :) Also try the Irvine carbon rod set, they are very strong and easy to use, good price as well!
i bought a flip 3d
1 Attachment(s)
I wonder if the kit has changed at all since I built mine when I hear what some people have said.
I dont think the tip design is a problem necessarily, it is usually over elevator with no engine that causes it to stop midair. so if you deadstick go real easy... there is a stack of drag on this plane. I went simple on controls. 3mm threaded rod, and used the supplied horns - I thought they were pretty good - best Ive seen supplied in an ARTF kit. RCME are publishing a kit review of it in the next issue (August) out in July, Someone talked about Nitro. I think the prosynth fuel is good. I use it in amny applications, but you do want at least 10% nitro. Fun flys are very abusive to engines, and they can get hot especially when in a cowl. heres a pic of mine.. |
i bought a flip 3d
1 Attachment(s)
and take offs are easy !
i bought a flip 3d
Hi all
Wen i said about the horns i actually ment the servo horns. As im just a dosey teenager i fogot to put in that they were for the servos. Archie Whens the new RCM&E out? Can you e-mail me a copy of it to: [email protected]. Im about to order one very soon (this week) and id like to know they build, fly etc. Is the flip good. What engine did you use. as i said im using the west 50t1. cant afford a ys and it needs 20% fuel. I use Bekra 10% fuel from model techics. Its designed for helis so it cools very well. Thanks Ian |
Ummm
Errr...
Output Arms.... yesy I suggest firmer ones definately. I chose Dubro Super strength arms. RCME out beginning of next month. Ummm Errrr.. how do I email you a copy of the RCM&E !? Flip aint bad, but I think it needs a more capable pilot than say the madness for example, on the whole, although some manouvres are easier with the flip, most notably torque rolls. I think West 50 with Mini Pipe will be a good option. |
i bought a flip 3d
Servo arms... servo arms... try dubro as mentioned before, they are great, if not a tad bulky. The Hanger 9 anodised ones are very good, lightweight and very strong... I think Ripmax or CSM Distribution have them.
i bought a flip 3d
Archie
Sorry, i ment a copy of the reviev not a copy of a whole magazine. How much are the du-bro super arms? Also will the capiche team be flying at wings n wheels on sunday Thanks Ian |
| All times are GMT -8. The time now is 05:24 PM. |
