depron ca
AZ
I've found the same problem. I used a "Foam safe" CA from my LHS and it worked great with an accelerator. Several guys have told me that if the CA has no odor then it should be safe on foam. The problem I find with Depron is the covering that is placed over the sheets. If I peel this off any foam safe CA seems to work.
TX
I use BS super gold plus...with accelerator. works great...very strong. during my initial build of the super xtra I used just plain Elmers white glue...tape the parts and wait...very good. 3M spray adhesive works very well too...only get one chance here.
I've heard great things about gorilla glue...they make a super glue now. haven't tried it but from what I've heard it works very well
