RCU Forums - View Single Post - prop question
Old 03-06-2006 | 06:47 PM
tail strike's Avatar
tail strike
Default RE: prop question
turn the propeller shaft till the piston is cumming up on the compression stroke then place the propeller at a 2 & 8 orientation and then drill the bolt holes (with a drill guide) at the appropriate
positions.
This will give you a good throw on the propeller to start the engine
