RCU Forums - View Single Post - Help with Structs-Trunion
Old 03-07-2006 | 08:12 PM
Edgar Perez's Avatar
Edgar Perez
My Feedback: (13)
Default RE: Help with Structs-Trunion
Wanted to post my solution for the record...
Couldn't get the struct hole opened enough with a screwdriver. Ended putting back the bolt in the trunion, screwing it completely. Once 'closed', I used a drill press with a 1/2 inch drilling bit. This resulted in just taking out enough material. After taking out the bolt, I used the screwdriver method and opened the hole, inserted the struct and screw the bolt in. Perfect.
Tried with several structs, all fine.
Thanks for the suggestions.
Regards,
Edgar
