RCU Forums - View Single Post - Just got the Phoenix Super Decathlon
Old 03-07-2006 | 10:03 PM
  #122
IronCross's Avatar
IronCross
Default RE: Just got the Phoenix Super Decathlon
Not to worry, it is a pretty easy build... Hardest part is probably getting engine positioned on the rails... I mounted the Saito as far back (towards the firewall) as it would go and still was about a quarter inch to far out on the prop flange... No biggie though .. I just fit the cowl to the front of the engine and mounted it there... This left a little gap on the bottom of the cowl but that is good.. A good space is needed down there for ventalation... Worked out good... I mention this because you may run into the same thing with your OS 4 stroke...
IC
