RE: Showtime
I finally check the incidence on the ST. The wings are off about .5* as is the stabilizers at .5*. It has always snapped to the right on a harn pull up and rocks bad in a harrier. Is .5* enough to worry about? What to use as 0 to level to see which wing needs to be moved? Was using the fuselage with the hatch removed as 0. Should the wing and stabilizer cords be 0 at this position?
