RCU Forums - View Single Post - mini servos in .40-size plane?
Old 03-10-2006 | 12:21 PM
boosted180
My Feedback: (8)
Default mini servos in .40-size plane?
what's a good quality mini servo i can use in a .40 size plane? i've been using mini ball bearing servos in my .40 ultimate and ahve had no problems, contrary to what some say. they are the hitec hs-85's. the only problem with them is too much slop around center (at least more than i'd like). but other than that they've held up fine. i've been using micro or mini servos for the trhottle as well in all of my .40-size planes and have not had any problems yet.
i'm putting together a pacific aeromodels edge right now and wanted to use mini servos (two) for the elevators. but this time i wanted something a little better quality, more precise. what brand/ model do you guys recommend? i want ball bearing and possibly metal gears also. or should i just stick to standard servos?
i want to go mini to save weight.
thanks.
