RCU Forums - View Single Post - How to run kevlar pull-pull
Old 03-10-2006 | 11:29 PM
Timthetoolman1's Avatar
Timthetoolman1
Default RE: How to run kevlar pull-pull
Thanks aerobatixkid, it's still frame work only, the issue is that one of the guys said the cable crosses inside. I tried it strait and it works great but it still touches the edges as it comes out. My question is rather or not I need to run this portion where it exits the fuse inside a piece of nylon tube so it doesn't rub the sides of the fuse and I think I do.
I took off the Klett tail wheel steering arms (the one mounted on the rudder), glassed back over the area I gouged out so I could put the servo arms there and I think all is well.
ID:	423951   Click image for larger version
