RCU Forums - View Single Post - 3W Throttle Arm Attachment
Old 03-12-2006 | 10:34 AM
off2fly
Default RE: 3W Throttle Arm Attachment
Ben,If you use weller a gun and use the smaller tip.You have to use staybrite silver solder on roll and use the correct flux it will solder on just fine.I always drill a hole and put a tiny bolt and nut through mie for added security.Hope this helps.
