ORIGINAL: DogAddict
I found a used nexstar setup for a good buy. It is a couple of years old, has the O.S. 46 fx in it and everything else. It has been flown very little and never been wrecked. What do I need to look at to make sure it's as good as he says it is?
Addict
To add to shussey is when you first turn on the transmitter don't extend the antanna just keep it collapse. of course "that's only while checking plane on the ground" and check the clevise pins to controls horn, I lost a Nexstar with a broken or defective clevis pin to the elevator control horn. I replaced them with metals types.
roltech
