Ben whatever you do don't take the butterfly shaft out,just get some stay brite solder and flux solder it on. The hole procedure takes less then 10min!If you take the butterfly off you have to brad the screw when you put it back together or the screw cac come loose and into the engine and engine into the trash.Loctite won't work!
