RCU Forums - View Single Post - What things should I get with the Nemesis?
Old 03-12-2006 | 08:29 PM
jombo's Avatar
jombo
Default RE: What things should I get with the Nemesis?
the only thing i would get are the axle stubs. just keep a set on hand untill they make a upgraded version. also they have a piece of tape on the tranny case where the reverse shifter is,just put a bead of silicone on the tape so it wont come off. when i got the genny le it came with a glow igniter a glow plug wrench a glow plug , well it came with just about everything except batt and fuel. oh, you will also need after run oil. i would put that in as soon as you get it . it will not only help in the rust dept but if your not going to run it for a while(like saturday the 11 was the only nice 60 degree day i had and my truck was sitting for a while)it will get rid of any condensation while being on the delivery truck for a week.also i never had a problem starting any of my trucks when i do this,it keeps the piston lubed and you will be able to pull the starter easier. also if you go with the rechargable batt pack like i did for breakin you will need 2, one pack for 2 tanks. i did 3 and in the middle of the 3rd the servos were jittery and dont forget a throttle return spring.
