RCU Forums - View Single Post - mini servos in .40-size plane?
Old 03-13-2006 | 06:39 AM
Jack Skip
Default RE: mini servos in .40-size plane?
I have had good results with the Hobbico CS 35. It weighs in at 2/3s the weight of a standard, but has better speed and torque. With 6v they have around 72 onzes and 0.11 second in speed. The cost is about $25. Tower has the generic version TS 35 for around $20.
I have some in an OMP Yak for 3D and they hold well.
They have a smaller case. If you are building, fit the openings to the servo. If not, add a bit of plywood to the opening.
