RE: 3W Throttle Arm Attachment
Hi,
I use a different approach. I use a long servo arm which is attached to the hole on the arm with a 2-56 bolt with lock nut. Before I tighten it down, I squeeze some RC-56 between the two surfaces. Then I adjust the angle and tighten the bolt. I have never had any problem with the arm loosening.
Elson
