RCU Forums - View Single Post - Genesis setup help
Old 03-13-2006 | 11:42 AM
roscottjr
My Feedback: (12)
Default RE: Genesis setup help
Hello. I was just wandering what to do to keep my front tires on the ground. When turning if I get on the throttle hard the truck has so much torque that it lifts 1 front tire way up off the ground and the other tries to pull straight. For instance, if I turn hard right and get on the throttl hard then it will pick up the right front tire off the ground, like several inches off the ground and the left will try to pull it straight then. Is there a fix for this or do I just need to ease up on the throttle when turning?
Robert
