RCU Forums - View Single Post - need support with tail support =)
Old 03-14-2006 | 09:27 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: need support with tail support =)
The best way I have found to do these is to drill the holes, and cut a piece of music wire to length (About 3/8" shorter that the distance from hole to hole)
Solder one of those electrical eyelets on ONE side and slip one on the other side.
Once all 8 wires are ready, screw them into position.
Now solder the other eyelet onto each wire - take precautions not to drip solder onto the covering! Or, if that makes you nervous, JB-Weld them in place.
