RCU Forums - View Single Post - First PTS P51 flight that i got to fly
Old 03-14-2006 | 06:06 PM
  #58
bruce88123
Default RE: First PTS P51 flight that i got to fly
ORIGINAL: riddell
On my P-51 PTS, I adjusted all the clevises to center with the radio on but now with the radio off the control surfaces do not line up. When I turn the radio on, they all line back up.
My question is:
Will the radio's function called "sub-trim" return the servos to the neutral position and make the control surfaces even whether the radio is on or off?
I don't think that will help. They should not move IF you turn off the RX first. I'm assuming you want it to be pretty when on static display.
You can use the sub-trim to position the servos so that you can re-center the trim levers/trim display. Can't remember if you have electronic or mechanical trim levers.
