RCU Forums - View Single Post - Best Clunk Setup???
Old 03-14-2006 | 07:13 PM
JoeAirPort's Avatar
JoeAirPort
My Feedback: (41)
Default RE: Best Clunk Setup???
This is the black flexible stuff. It's the best clunk line out there. Just make sure to divide the clunk line in two by putting a short piece of brass tubing in the middle. That's because this stuff is so flexible it could end up stuck at the front of the tank if you use a really heavy clunk (most people use the large one on these tank setups). If you put the extra piece of brass tubing in the middle it will be fine.
http://www.ronlund.com/Merchant2/mer...ct_Code=HAY249
