Best Clunk Setup???
MI
Hi all,
I'm setting up my first gasser, A Texas Hurricane ARF w/ a Brison 2.4, and was wondering what is the best clunk set-up. I tried a piece of tygon and the standard clunk that comes in a Dubro 20 oz tank, but it just isn't flexible enough. Should I go with a heavy clunk and Tygon or neoprene and the standard clunk? One person I talked to suggested a felt pick-up from a weed wacker or similar piece of small eqiupment. Has any one tried that? Are gassers very sensitive to going lean if the clunk isn't always submerged?
FF
FF
MO
I use fuel line I got from Airwild I believe it is called Aerotrend fuel tubing it is more flexible than tygon and works well. but I have also had tygon in several planes with no trouble. but either way you should replace it yearly they tend to get hard and brittle after a while. and yes use a large clunk
My Feedback: (41)
This is the black flexible stuff. It's the best clunk line out there. Just make sure to divide the clunk line in two by putting a short piece of brass tubing in the middle. That's because this stuff is so flexible it could end up stuck at the front of the tank if you use a really heavy clunk (most people use the large one on these tank setups). If you put the extra piece of brass tubing in the middle it will be fine.
http://www.ronlund.com/Merchant2/mer...ct_Code=HAY249
My Feedback: (41)
Bill, I have to confess that I need to convert my BME Edge 30% to that system too. At first I had the Hayes stuff without the piece of brass tubing in the middle and the clunk would go to the front of the tank when I turned the tank upside down (every time). So I used the Tygon for the first 4 flights. Now I need to go back and put the black stuff back in (and do it right this time).
ORIGINAL: rcbill
It's always more fun to do something at least 2 or 3 times.
I've been using DuBro neoprene with a standard weight clunk that comes with the DuBro tanks. No problems so far.
I did learn the tygon lesson the hard way. I never new that it would get stiff over time. Mine became unflexible and then it slid off the brass tube. DEADSTICK about 2 minutes into a flight.
Whats dat funny sound in the tank? Somfin rattlin' round in there. DOH!! Howd dat happen? [:-]
Been using neoprene ever since. I don't know how long it lasts. Never had a plane last more than a couple seasons before I stuffed it.
OK
I am using a 20oz Dubro tank in my Giant Stick with Tygon line and the Walbro fiber filter clunk. Works like a charm for me so I don't think that the clunk being partially out of fuel at times is a problem. I can pretty much run the tank out and haven't noticed any problems using the fiber filter clunk. It is also fairly heavy and the Tygon line fits very tight. I soldered fuel barbs to the brass tank tubes.
Like I said, works fine for me. I think the clunks cost about $3.25 at one of the local Lawn and Garden shops (NOT a Lowes or Home Depot type).
my .02 on this one.
Dan
my .02 on this one.
Dan
I use snowmobile primer line and weedwacker clunk with the felt filters. I tried Tygon but found it goes hard after about a year. The primer line doesn't.
