RCU Forums - View Single Post - Futaba Freq Modules
Old 12-07-2002 | 02:16 AM
Trucker-RCU
Default Futaba Freq Modules
Yes, actually the 9C works as regular Fm or PCM. You select either mode. The 9CHP and 9CHF use the same transmitter, just the receiver that comes with system is different. I have a 9C transmitter and use it on both FM and PCM. Got PCM rec in heli, and FM systems in 6 airplanes. So far I really like the system, easy to program and very flexible. When you want to change freq just pop in another FP-TP-FM module. With the module you don't have to worry about lo and hi band tuning, its all done with module.
