RCU Forums - View Single Post - Aerobatic flight using video goggle
Old 03-15-2006 | 02:40 AM
vrflyer
Default Aerobatic flight using video goggle
I post this yesteray in the section sport flying, I was in the wrong section, I start again:
I installed two cameras onboard my Funtana and fly with video goggle. I use goggle from take-off to landing. Last summer I practice aerobatic flight to know what is possible to do using only video to control the planes. The cameras are inside the wings. One camera looking front and one cam looking down. I use the down cam only when flying vertical. The horizon appear in the center of the video when the planes is level(front cam) or the planes is vertical (down cam). I made a video switch plug in the gear channel to change cam while flying.
http://video.google.com/videoplay?do...17858714442651
the next step will be to install camera in the cockpit of a Capmaniac, the pan and tilt will be control directly by the movement of my head. later in the summer.
To watch the video you need Goggle video player:
http://video.google.com/playerdownload.html
ID:	426314   Click image for larger version
