RCU Forums - View Single Post - Trex SE Tail Boom Mounting Problem
Old 03-16-2006 | 01:30 PM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: Trex SE Tail Boom Mounting Problem
You are doing it right, a set of hardened hex drivers are nice.
If you strip the screw you will have to use a dremel cutting wheel and cut a straight slot accross it and use a straight slot screw driver on it. You can try heating the screw head gently with a soldering iron, sometimes that will let the locktite break loose but don't over do it.
