RE: NEW QUEST
I have used monokote or ultra to seal the gaps, and that in of its self is a hinge if done on both sides that is very strong. Using the correct color the mono can hardly be seen and helps to reduce the chance of flutter of the surface on those high speed on the deck inverted passes.
