RE: YS Engines back
I've used Hayes, Dubro, Sullivan, GP and asian ARF tanks with no problem. I would be wary of anything that had a clear molding seam that might split, but I've never seen it happen on my YS 63-91-110-120's.
The recommendation on three turns out on the regulator for the 110 does seem to be important with the 110's. I've run two of them, one tuned up right by the book and runs great, the other tuned up by the book and started dead-sticking on a regular basis after the first ten tanks. It would run great on the ground, but after five minutes in the air it would die when I would try to throttle up from idle on down-lines. I'm told the three-turns-out setting is the fix for this behavior.
