RCU Forums - View Single Post - Thunder Tiger PRO-39 engine to Shuttle
Old 03-17-2006 | 04:09 PM
Gorgok
Default RE: Thunder Tiger PRO-39 engine to Shuttle
Any .30-.39 should have the same mounting pattern, so it should fit. (The Toki .40 does as well.)
To make it work, all you would need to do is put the washer, clutch, fan assembly and nut on the crank shaft, and put it in the heli. Depending on the heli, you might need to change the throttle arm on the carb, that usually is supplied with the heli kit though.
