Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
 Thunder Tiger PRO-39 engine to Shuttle >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 03-17-2006 | 02:22 PM
Default Thunder Tiger PRO-39 engine to Shuttle
Hi all!
Im planning to update my raptor 30 to 50 so i have one motor without any use. I have also old Shuttle without use. My question is can i use that TT engine with Shuttle? If yes what i have to do? Or is it even possible to fit? Any problems?
Old 03-17-2006 | 02:35 PM
Default RE: Thunder Tiger PRO-39 engine to Shuttle
as far as i know the tt39 engine should go strait into the schuttel
Old 03-17-2006 | 04:09 PM
Any .30-.39 should have the same mounting pattern, so it should fit. (The Toki .40 does as well.)
To make it work, all you would need to do is put the washer, clutch, fan assembly and nut on the crank shaft, and put it in the heli. Depending on the heli, you might need to change the throttle arm on the carb, that usually is supplied with the heli kit though.
Old 03-17-2006 | 04:13 PM
Thank you Gorgok and Jez33
