RE: ?? on mini-T ball diffs
Try turing it aroud but if that doesnt work put some thread lock on the bolt. I put a mip ball diff in my mini lst and had a problem with it loosening up. Since I put the thread lock on it, its been fine. Also with my xxx-t mf2 I have noticed that if the thrust bearing are not set right or lubed enough it will cause it to loosen(just something to think about)
