RE: E-flite Ultimate FX
This thing is a fun little foamie. I had to modify mine to mount the battery aft in order to balance it with the AON motor I am using. I have a review I need to send in to AON with this motor in an Edge and now this plane. Its a "400" sized motor I am using with the gear box.
Enough talking I will post the hovering down on the deck (or should I say water) I took at the beach Sunday. Flies pretty cool but not as good as my 29% ultimate. If you want to go with an in runner do yourself a favor and get the AON or park 400 sized in runner. Ill show the pics of the mods I did. I used some hot melt glue which I know made it a little heavier but it has held up awesome.
The thing lands so easy. I just harrier it in everytime. I have mine balanced at 4". I need to change the setup for the rudder to be pull-pull. I am also thinking longer servo arms for the elevator and or switching to an HS 56 like I have on the ailerons.
Does not come close to myTBM monte but its a cool mix of foamie and built up style plane.
