RE: Plane Goes Crazy!
Ok Guys.
1. I have a voltmeter and double checked my Rx battery. It reads 5.32 so no problem there. Note: Battery is 4.8
2. I checked the antenna on the transmitter and it was fully screwed so no problem there.
3. I did another range check with antenna fully collapsed and the plane's servos moved less at about 300 ft from it. Is that right?
4. I checked the muffler and it was nice and tight.
All I have to do is check the receiver connections and crystal and do a range check with the engine running.
Anything left?
