RE: NEW QUEST
Olstoney,
I bet Eric will step in but I too have a QII ready to assemble.
The Hyde mount should not be a problem.
If you order the one for the 1.10 from Central Hobbies it comes predrilled for the 1.10 placing the engine thrust washer at the correct spacing from the firewall.
I couldn't believe it!!!!!!
To mount the motor mount I plan to layout a "crosshair" on the firewall using Eric's measurements.
I will then lightly tack glue the mount to the firewall after I have the "crosshairs" centered in the mount's rear hole. After laying out the holes to attach the mount I will break the mount free from the firewall...
Remember just LIGHTLY tack glue the mount.
As far as reenforcing the landing gear Eric suggests an epoxy impregnated glass cloth "bandaid" over the gear plate.
Voila!!!!!
Should be easy!
Good luck!
JLK
