mounting the motor
lots of motors are mounted upside down,some times at idle the engine may run a little rough or the idle needs to be adjusted a little faster,with the inverted engine the glow plug can get a little wetter. Main thing is to line the fuel tank with the carb. spray bar,center of fuel tank to 3/8 above center to spray bar on carb.works good.
