hello
i used some aluininm [how ever its spelled ] square tubes and mounted them on the inside of the outer toung tubes for the box to rest on so the box sits about 1. 5 inches back from the outside edge, wich in turn moved the box back away from the toung jack and out of harms way if it ever jack knifed god forbid! i drilled and used 10x24 bolts & nylock nuts for mounting the box down and drilled & taped the inner toung tubes for the square tubing .my set up is the first one on page 23 in this forum. hope i helped see ys stan
http://www.rcuniverse.com/forum/m_11...23/key_/tm.htm
