RCU Forums - View Single Post - Need Help with Kyosho Stearman 40
Old 12-09-2002 | 05:22 AM
Grayoon
Default Need Help with Kyosho Stearman 40
Ok, i just got this thing built on Friday. Flew it Saturday morning and i had to put lots of down elevator in it...from neutral point that is. So i talked to a couple of guys at the field. One suggested maybe i needed some down thrust. Again, i had to put lots of down elevator in it to keep it from nosing up the whole time. They also checked the CG for me and it seemed to balance right. S
So, i went back home and put two washers behind the top of the motor mount to give some down thrust. Went today and the same thing. So i need some ideas on what this problem could be. PLEASE HELP!!!! It is a fun little airplane but it is a little on the hairy side on the up/down...it goes one way or the other too easily. And again, i have lots of down trim in it. Would like it to fly level when the elevator is in the level position....not in the way down elevator position.
Thanks many.
