RCU Forums - View Single Post - Supertiger .29 need help
Old 12-09-2002 | 10:46 PM
1/2a phil
Default Supertiger .29 need help
Good news, I set the small and large needles as said, and also repaired the one bent one, and she fired up. Ran into two more problems though. First it seems like the fuel wants to go backwards down the fuel line. This might be because I only have about 1/2oz of fuel left. I need to make a run down to the LHS and buy some sort of hand fuel pump, because I was using my friends fuel and pump.
Second problem, it seemed like the high speed needle was backing off when the motor was running. The other needle valve can't do this do to some sort of locking clips. Is my motor missing something? Maybe some teflon tape on the threads?
Philip
