Originally posted by Damnathius
Also, if you're using an OS 40 or 46, consider getting a Heavy Hub to put inside the spinner, or the proper size aluminum spinner to balance the model. I had to do this on two of these planes, with 3 different engines: OS .46 FX, OS .46 LA, and an OS .52 FS. Have fun... It's a great flying plane.
[/B]
I put an OS 48 4s in mine. The heavy hub was a good help with the balance. It was achieved without weights by putting the battery and receiver under the dash area. I tried to get the battery over the tank but it wouldn't fit so I stacked it and the rx just behind the tank. It balanced as advertised, right on 3 3/8.
I set the throws and now have to get into the air.
