RE: Question about Fox 3.2
There is no exact setting...Every engine is different...Start 2 turns out on both and peak the high, then start leaning the low until the transition is bad...Richen the low until the transition is good and back and re set the high for peak rpm, then back it off until the engine just starts to slow down..Should be good to go...
