RCU Forums - View Single Post - Super 8 Question
Old 12-09-2002 | 11:21 PM
John Wells's Avatar
John Wells
My Feedback: (10)
Default Super 8 Question
Hi Ms. Cross, I have a question about my elevator dual rate switch. When I have a dual rate setting of perhaps 40%, and lets say, 100% or more on high rates (elevator), the elevator neutral moves a tiny bit (and stays at the new neutral location) when I flip between high and low rates. The elevator works fine, and when I change back to D/R, it goes to the original neutral location. The elevator change is very little, but I don't think it should be doing that?! Changing the expo makes no difference. Have you ever heard of this? It does it with both futaba and hitec receivers / servos. If I keep the dual rates fairly close on either side of the switch, ie. 80% and 100%, it doesn't do it. Grossly different dual rate settings seem to cause it. This appears to only happen with the elevator D/R switch. I can live with this, but I was wondering if there's something I could do to correct it. Thanks for any suggestions.
John Wells
