ORIGINAL: ashburg
um, I just did some light bashing with the X1 CRT, came down on the rear end, and bent the whole rear bulhead so far upwards that it bent the rear driveshaft like a pretzel and crushed the "support" beam up against something else (I'm afraid to look). Is there a cure for this flimsy RTR frame out there? I remember seeing a brownish chassis in this thread somewhere, is that a really really ridgid chassis or...what would y'all do?
The savage x got a beating too...busted fuel tank (2nd one) and broken metal steering servo gear. With the fuel tank, I'm thinking I'm going to fashion some inboard mounted tank somehow.
As for the the CRT, you can get a BCE chassis, but you have to do some searching on truggyracers.com to find him. You can also get the pro chassis off of ebay from people who purchased a BCE chassis for around $40. I have one but I have not decided if I going to sell it. As for the Savage, loosen up your servo saver alittle and take a look at this
http://www.fastlanemachine.com/Publi...6/Default.aspx
you can use the tank and servo mount plate to do a professional mod with out all the work. There extended chassis is the bomb!
