Zippi
I will let you know how the CMP Giles-202 works out with the Brillelli 25GT. I have it here and will be putting it together once I get back from the RC show in Toledo in a couple of weeks. The only thing wrong with the CMP Giles-202 is you have to use a monokote sealer on the trim other wise it may come loss during flight. The plane weighs in at 10.25lbs with a OS Glow 160 2- stroke. That engine weighs 2lbs. The Brillelli 25GT with EI is a little under 3lbs. That should give me a scale stunt plane weighing around 12lbs or less. With the Brillelli 25GT spinning a APC 17x6 prop at 8800 RPM and pulling 14lbs thrust I cannot weight to fly this bird. I'll keep you in touch.
