RE: Pusher Prop Setup?
Can't help you on what size prop you want but regarding setting it up you want to have your prop facing forward just like if it were on the nose and run the motor in reverse. With your brushless, if it is going the wrong way simply swap out one of your connections and it will turn the other direction.
