Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Pusher Prop Setup?
Old 03-26-2006 | 09:06 PM
Default Pusher Prop Setup?
Ok, I know this isnt a jet but it involves pusher props so. I would like to build a mugi evo (http://www.mugi.co.uk/evo_intro.php), but Im not too sure how to set up a pusher prop. I have an eflite park 400 outrunner. What would i have to do to make this a pusher, and what size prop would you recomend using (the plane will probabally be about 16oz). Thanks.
Old 03-26-2006 | 10:13 PM
vicman's Avatar
My Feedback: (10)
Default RE: Pusher Prop Setup?
Can't help you on what size prop you want but regarding setting it up you want to have your prop facing forward just like if it were on the nose and run the motor in reverse. With your brushless, if it is going the wrong way simply swap out one of your connections and it will turn the other direction.
Old 03-27-2006 | 08:21 PM
Ok, thanks a lot... i was pretty sure thats all I had to do but i just wanted to make sure.
Old 03-27-2006 | 10:07 PM
vicman's Avatar
My Feedback: (10)
Glad to help
