RE: NEED Taurus Control Throws--HELP
Set up high rate for as much control throw as you can get on all surfaces without making the servos buzz. Then set up low rate for something around 60%. You'll be fine.
The old reed controlled models had very small control surfaces, since all they had was max throw or nothing at all. It is extremely difficult to get too much control throw on those old models when using proportional radios and stock control surfaces.
