RE: full house sailplane servo setup?
The servos are hitec HS85MG servos. I had to turn them on their sides and cut off on arm due to shallow servo bays.I mounted them on each aileron and flap so they "mirror" each other with servo arms facing outboard towards wing tips. I used heavy duty sticky tape. They are stuck pretty good, but I can work them loose if need be with a little effort.
Thanks for your thoughts and help.
Dan
