RCU Forums - View Single Post - Done!!!
Thread: Done!!!
Old 03-28-2006 | 06:24 AM
bkdavy's Avatar
bkdavy
Default RE: Done!!!
I seem to have gotten one of my alerions on at a slant. One side is high, and one is low... grrr.
I hope this means that one aileron is up and the other is down with the stick in the neutral position. If so, this is easy to fix by adjusting the linkages. If it means that one end of the aileron is up and the other is down, then your aileron is warped, and your instructor will probably not OK the plane. This will require replacement of the aileron.
Good luck.
Brad
